Issues with Mobile data network and wifi
(Topic created on: 08-09-2023 05:12 PM)
Tannawys23ultra
Beginner Level 3
Hi All
I am using s23ultra, purchased in May 2023. I am facing lot of issues with mobile data and wifi data connectivity.
Speed is really poor, even though it shows good network speed. Both on mobile and wifi connectivity. Is there anyone else facing the similar issues??
Responses would be appreciated
#s23ultra
5 Comments
hojoo
I'm facing same issue on m14
SKBilal-AHMED53
ALWAYS N E Twonk Loose C CONNECTION DOSN'T GET MOBIL E DATA NETwork.
goodthings
My dear reset network setting & also reset all setting of your's device. Thanks.
cs_member10
Dear Samsung member,
We acknowledge your query and apologize for the inconvenience caused to you and will surely assist you regarding the same and please follow the easy troubleshooting steps which might help to solve the issue.
Kindly restart your smartphone once and also re-insert your SIM card.
Check device network in an open area: Kindly check your device in a different location/network coverage area.
Check device network mode settings
Please follow the below steps.
Step1: Navigate to the app's screen and tap on Settings.
Step2: Tap on Connections.
Step3: Tap on Mobile networks.
Step4: Tap on network mode SIM1 or SIM2.
Step5: Select network mode.
Note: We recommend setting device network mode as 5G/LTE/3G/2G(auto connect) mode.
Kindly do check the same SIM card in another phone or another SIM card on the same phone to verify the issue.
And please follow the easy troubleshooting steps which might help to solve the Wi-Fiissue.
Note: Any prompt that says "Authentication Error" is related to an incorrect password. Please contact your Internet Service Provider for assistance regarding changing your Wi-Fi network password.
1: Settings >> Connections >> Wi-Fi >> W-Fi network >> Tap and hold the Wi-Fi network that you're having trouble with until the menu allows you to select Forget Network.
2: Reset Network Settings: Setting >> General Management >> Reset >> Reset Network Setting.
3: Restart the Router and Mobile Device. Switch off your Router (at the wall or with the power button on the router) and wait for 2-3 minutes before switching it on. While you're waiting, press the Power button on your mobile device and select Restart.
Once the router has been successfully connected to the internet again, try to connect to your network on your mobile device.
Make sure there is no interference between the router and your mobile device. Concrete walls, fridges, and microwaves can all interrupt the Wi-Fi signal.
4: Disable flight mode. Find the Airplane/Flight mode option and turn it off.
In case the issue still occurs. Please register your concern in Samsung Members Application (Open Samsung Members Application > Support> Tap on error report > Type your query > Send).
Tannawys23ultra
Beginner Level 3
Ok let me try these steps and get back to you
