Mobile Network Problem
(Topic created on: 09-11-2025 04:01 PM)
pabh
After the September 2025 patch update, getting connectivity issues on Samsung S22 Ultra, in addition the battery is draining quick then usual time. I dont know if the company is following "failed obsolescence policy" a planned obsolescence by slowing down older phones through software updates without adequate consumer disclosure. This will shorten product lifespan in long run.
cs_member10
Dear Samsung Member,
● Galaxy device network issue: https://www.samsung.com/in/support/mobile-devices/samsung-galaxy-smartphone-how-to-optimise-network-...
