08-17-2024 08:33 PM in
Galaxy S- Mark as New
08-18-2024 12:46 AM in
08-18-2024 03:58 PM in
08-20-2024 02:33 PM in
08-20-2024 07:27 PM in
08-20-2024 02:08 PM in
Galaxy SDear Samsung Member,
1 After launching the Galaxy Wearable app on a mobile device, you can select to listen to ambient sounds and adjust the volume of surrounding sound or choose active noise cancellation and control its intensity.
*Path: Galaxy wearable > Choose Ambient sound or Active noise canceling> Adjust volume or level.
2. Kindly check the dust or clean the tips of the buds and check once.
3. Kindly check the Accessibility sound check with normal.
Path: Galaxy Wearable> Earbuds settings>Accessibility.
Left/right sound balance: Adjust the left and right volume balance if you have a hearing impairment or if using a single earbud is more convenient. Drag the Left/ Right sound balance adjustment bar to adjust the balance. If you drag the bar to the left, the left earbud’s volume will increase and vice versa.
08-20-2024 02:31 PM (Last edited 08-20-2024 02:32 PM ) in
