Resolved! Solved
Issue with power mode after update
(Topic created on: 08-13-2020 02:07 AM)
T_
The power mode seems to set back to optimized every time you connect phone yo charger and disconnect it even though the power mode was set to medium power saving prior to connecting the charger after the August security update on S10.
Is anyone else facing this issue?
Not applicable
it's not issue ......it is like that only if you switched on adaptive power saving option ....adaptive power saving mechanism work that way 👉 if it learn that your device need to save power consumption 🔋 then automatically it will switched on to medium power saving....and when your charge is full or little charged then it understand that now your device battery have maximum power so no need medium power saving mode so it will again seted as optimised ....it's not after update this function still presents from version 2.0 same for all
3 Comments
Not applicable
JayShingala
just turn off adaptive power saving option your problem is solved
NilambharNjns
all device n app optimize.
