Issue while opening Home Up
(Topic created on: 04-27-2025 03:17 PM)
Abhicrik
After upgrading my tab S10 Ultra to One Ui 7, i am unable to access home up plugin in good lock. Getting this strange error everytime which i have shared the photo. I have tried uninstalling and then reinstalling good lock app multiple times but no solution. Does anyone know the solution ?
6 Comments
Samsung is working on a patch for this. Read in the news. Mostly by next week the patch will arrive.
Abhicrik
By patch you mean update ?
ezraken
Yes
Abhicrik
Ok. Thanks
Janmajaya123
Samsung users, we need your voice!
You also suffering from any issues that you have? You're not alone!
Like, comment & support this post to make Samsung listen!
Click now: https://r2.community.samsung.com/t5/Galaxy-A/Samsung-s-Response-Isn-t-Enough-Look-What-They-Said/td-...
cs_member10
Dear Samsung Member,
We request you kindly share the log file. Also, share the video clips and images for better understanding. This will help us to investigate further and resolve this issue.
To share the log file: Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> Select the appropriate issue category> Type your query and send.
