Issue for mobile
(Topic created on: 01-20-2024 09:44 PM)
raj0055
I am facing a issue with my device last one month some app crash, leg and many time auto restart my phone s22 ultra
7 Comments
AJAB_MORIA
After Ui6?
raj0055
Before UI 6
goodthings
Reset factory data with backup then try to it's again also turn off Auto restart in device care. Thanks.
goodthings
Your's most welcome to here.
raj0055
I am already reset factory data but problem continue
cs_member10
Dear Samsung Member,
Kindly follow the easy troubleshooting steps which might help to solve the hang issue.
Check space availability
Kindly check the space on your device:
Path: Settings > Battery and device Care > Storage
To improve the device performance there should be sufficient space.
Kindly check the RAM in your device:
Path: Settings > Battery and device Care > Memory
The device's RAM should be free to improve performance. So clear the RAM memory once a day
Clear app cache through Device care:
Settings > Device care > Storage > CLEAN NOW.
Note: To delete files or uninstall apps that you do not use anymore, select a category under USER DATA. Then, tick items to select and tap DELETE or UNINSTALL.
The clear cache memory of a particular application:
Settings > Apps > Now pick the app that you like to clear off the cache memory > Storage > Clear Cache.
Close Background Apps
Is there any unnecessary application running in the background?
Too many applications running in the background may cause the device to hang. Kindly close the background running applications in the device (''Tap the left side key & close the background running application'').
Kindly follow the easy troubleshooting steps which might help to solve the app crash issue.
Clearing the app cache is kind of like a cleanse for your apps. It will get rid of residual files that could be slowing down the app.
Open Settings, and then swipe to and tap Apps. Select or search for the app you want to clear. Tap Storage, and then tap Clear cache.
Step 1. Go to Settings > Apps.
Step 2. Tap on More options (three vertical dots) on upper-right corner > Sort by > Size.
To delete:
Step 2. Select an issued app.
Step 3. Tap Uninstall to free up storage space.
Improper App installation may also cause Android Apps crashing problem. You must download the App from the Google Play Store/ Galaxy store and use it only after it is successfully and completely installed on your device. In case your Apps stop abruptly, delete or uninstall the App from your device and install it back carefully after a few minutes.
Step 1. To uninstall apps on an Android device, go to Settings > Apps.
Step 2. Select an issued app > tap on Uninstall.
Step 3. Go to Google Play Store and reinstall the App again.
Kindly follow the easy troubleshooting steps which might help to solve the restart issue.
Kindly use genuine Samsung charger.
Note: We always recommend to use genuine Samsung charger for charging your device.
Disable auto restart function
There are two methods to disable auto restart function
Method 1
Note: Device screenshots and menu may vary depending on the device model and software version.
Step1: Navigate to apps screen and tap on Settings.
Step2: Tap on General management.
Step3: Tap on Reset.
Step4: Disable Auto restart (if enabled).
Step5: Auto restart disabled.
Method 2
Step1: Go to "Settings"
Step2: Tap on "Battery and device care"
Step3: Tap on Three dots
Step4: Tap on "Automation"
Step5: Disable "Auto restart at set times" if enabled
Check the device in safe mode: https://www.samsung.com/in/support/mobile-devices/safe-mode-on-samsung-phones/
Update device software (If Software update available): https://www.samsung.com/in/support/mobile-devices/samsung-galaxy-smartphone-how-to-update-software/
Reset the device: https://www.samsung.com/in/support/mobile-devices/samsung-galaxy-mobile-how-to-perform-a-factory-res...
In case the issue still occurs. Please visit the service center for a physical inspection of your device. You can locate your nearest service center with this given link: https://www.samsung.com/in/support/service-center/
Akhil406
Remove 85% battery option
