Internet connection problem in my s24 plus
(Topic created on: 03-14-2025 08:46 AM)
arunkumaryadav
When one sim closed then internet connection in other sim will stable but both sim active mode lots of problem in stable internet connection why...
3 Comments
Kumarsir
Also my s22 ultra
This issue occurs because both SIMs share network resources, affecting signal stability and bandwidth. Here’s why your internet connection improves when one SIM is disabled:
📶 Network Prioritization – When both SIMs are active, your phone constantly switches between networks, leading to unstable connections.
🔄 Dual SIM Standby Limitation – Most phones, including Samsung, use Dual SIM Dual Standby (DSDS), meaning only one SIM can actively use data at a time, causing delays in switching.
📡 Network Interference – If both SIMs are from different carriers, they may use different frequency bands, leading to signal conflicts.
Power Consumption & Throttling – Running two SIMs increases battery usage, causing performance drops that affect network stability.
🔧 Possible Solutions:
✔️ Use one SIM for calls & SMS, and the other for mobile data (Settings → SIM Manager).
✔️ Try locking your data SIM to a specific network mode (e.g., 5G/4G).
✔️ If possible, switch to a single high-speed SIM for better stability.
If this was helpful, please click on the three dots (⋮) on my comment and select "Accept Solution" 😊.
cs_member10
Dear Samsung Member,
Please perform the below-mentioned troubleshooting steps, these may help in resolving your concerns.
● Galaxy device internet issue: https://www.samsung.com/in/support/mobile-devices/how-to-troubleshoot-mobile-data-issues/
● Galaxy device network issue: https://www.samsung.com/in/support/mobile-devices/samsung-galaxy-smartphone-how-to-optimise-network-...
If the issue still occurs, please visit the service centre for a physical inspection of your device. You can locate your nearest service centre with this given link: https://www.samsung.com/in/support/service-center/
