01-28-2025 08:40 PM in
Galaxy S- Mark as New
01-28-2025 09:03 PM in
01-28-2025 09:06 PM in
Galaxy SGo to Settings > Sounds and Vibration > Sound quality and effects > Adapt Sound.
Disable Adapt Sound
01-28-2025 09:07 PM in
01-28-2025 09:52 PM in
01-29-2025 09:15 AM in
Galaxy SDear Samsung Member,
Please perform the below-mentioned troubleshooting steps, these may help in resolving your concerns.
● Check app cache: Settings > Device care > Storage > CLEAN NOW.
● The clear cache memory of a particular application: Settings > Apps > Now pick the app you like to clear off the cache memory > Storage > Clear Cache.
● Reset the device Settings: Settings > General Management > Reset settings>Reset all settings to their default.
3. If you do not remember password then advise to reset (Forgot password) your Google account.
If the issue still occurs, please visit the service centre for a physical inspection of your device. You can locate your nearest service centre with this given link: https://www.samsung.com/in/support/service-center/
