Ringtone Fading At Start And Sound Issues
(Topic created on: 07-29-2022 11:36 PM)
Kaizaadbanaji2608
I Am Using An S22 Ultra And I Noticed That Ringtone Volume Is Low In The Start And It Gradually Increased Could Someone Help Me Get It Disabled
 I've opened settings > Sounds and Vibations > Selected a ringtone > The sound was very good and loud and comes from the bottom speaker and the ear speaker.
BUT when I got a phone call the ringtone sounded very low.
When we play it in the ringtone section it plays very well and loud.
Even while playing music the sound is not as it should be.
cs_member8
Dear Samsung Customer,
1. Disconnect anything plugged into the headphone jack like, selfie stick, headphone, Bluetooth, etc.
2. Remove any third-party case, protective films, or any other accessory that usually comes in contact with your device. (If any)
Check device volume settings
Please follow the below steps:
Step1: Navigate to apps screen and tap on Settings.
Step2: Tap on Sound & vibration.
Step3: Tap on Volume.
Step4: Drag the volume adjustment bar left or right to increase or decrease the device volume.
To verify, play music and check the music sound. If the sound quality is good, then your speaker is working fine.
Clear Sound picker data
Step1: Got to Settings
Step2: Apps
Step3: Filter and sort
Step4: Enable "Show system apps"
Step5: Tap "OK"
Step6: Search Sound Picker
Step7: Tap on storage
Step8: clear data of Sound picker.
In case the issue still occurs. Please register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Ask question).
Thank you for writing to us.
Samsung Customer Support.
