Idle battery drain
(Topic created on: 09-08-2021 06:20 AM)
iamrohitkm
I am facing huge idle battery drain in my S10. Around 5 to 6%. Usually when the data is off idle battery drain should be 1 to 2%. Is anyone facing the same issue?
The excitement will be short lived. The thing is Samsung provides so many features & lots of additional apps that it increases the background services. Samsung users need to sacrifice some battery life for the additional features they get. Just compare the 'running services' in developer settings with another stock android phone & see the difference yourself
Yeah true that
If it's over 5% check any rogue apps running in background. Try safe mode and see the drain
iamrohitkm
Can it be due to 2 Sims?
No
No, unless you are in weak network area
Sorry some battery drain issues are there with one ui 3 it will optimize on one ui 4 updates
And turn on adaptive power mode
And frequent restart option at night to save battery at night only 1 or 2% will drain at night if you turn above on
iamrohitkm
Oh k why can't they rectify in this one ui 3 only why in one ui 4?
Umm I dont Know im not an dev
There are more optimizations
On one ui 4
Dont know why not fixing on 3
sammy25
Check in battery care-》background usage limit.
Click in graph to get a time range and check which apps are running at that time in background.
Put those unnecessary apps to sleep.
