How to wipe cache partition on Samsung S20 Ultra running Android 12
(Topic created on: 01-07-2022 11:42 PM)
ketani72
I had opted for One UI 4.0 Beta running Android 12 on my Samsung S20 Ultra.
Just received Stable Android 12 update a couple of days ago, now I want to know how to wipe cache partition on Android 12.
Is it the same way as it was with Android 11 ?
4 Comments
igauravmishra
Go to recovery mode I think, u may need to connect your phone to PC and adb tools and then type the command 'adb reboot recovery', device will boot to recovery and choose clear cache
WalkieTechie
Expert Level 4
Yes, it should be the same. Just clear cache after entering the boot menu.
Yes...
yaxJordan
Also, you can open boot setup by plugin type c headset..
