How to slove FPS issue
(Topic created on: 05-17-2020 12:20 AM)
Reshu143
I'm using S9+
During pubg game play, it gets high temperature due to hotness it is difficult  to hold phone in hand.
And you can see in right corner it gives 18 FPS only.
Can you please  give me solutions.
15 Comments
Reshu143
sorry FPS is showing in left corner
Š
Game booster plus. Max FPS
AravindanR
If its possible try to play games in a cool environment, Like a room with AC. Remove any protective case from phone when playing. Try to reduce the FPS to 40 to 45 from custom settings in game plugins app if you are playing for more than an hour in a hot environment. Though you will not get max FPS but the FPS will be stable. Use Max fps settings only if you have a cool environment. Phone will heat up very quickly and frames will drop if not.
Reshu143
sorry but i don't have ac but i play in normal temperature like 25 26 c
raj0056
Not only S9 bro..my S10 Plus gets heated while playing pubg...
Samsung need to think on this..as we are spending hige amount for premium mobiles...
Reshu143
Right bro
AravindanR
Every mobile device gets heated when playing pubg. But other brands do not thermal throttle the cpu so soon as Exynos. It is true Samsung should do something to resolve this thermal throttle issue. until then if you want to play extended amount of time without harming the cpu, Then reducing the Fps is the only option. When the phone is in a hot environment I set the fps to 30 to 45. The phone will not get heated that much with reduced fps settings and you will have a stable game play for extended amount of time.
oyemukul
s8 is also in same problem.
heated very much while playing pubg.
