How to change camera shutter sound in my s23 fe?
(Topic created on: 11-16-2024 09:52 PM)
asinha
After the recent updates, the camera shutter sound of my s23 fe has automatically changed to an annoying tone
I am unable to search for the setting to change the shutter sound. kindly guide.
2 Comments
You can not change the shutter sound.
cs_member10
Dear Samsung Member,
As per your concern, we want to inform you that there is no such option in samsung to change the camera shutter sound. If you want then you can disable it by using the below given path.
Path: Camera app> Settings> Swipe to and tap the switch next to the Shutter sound to disable it.
