Heating problem
(Topic created on: 04-17-2023 04:29 PM)
Chote5838
My Samsung galaxy S21 fe got heating problem after the 5.1 One UI. Is there any solution for that.
3 Comments
goodthings
My dear, remove fone cover , fone protect from sunlight and heat in this summer season, don't fone put into the closed bag . Fone switch off for some time and open it's after some time. Reset all settings of your's fone .if you like these solutions then accept as solution and top upper right three dots press . Thanks with a warm regards.
IcyJay30
Expert Level 4
Turn off ram plus, adaptive battery, wifi and Bluetooth scanning in location service
cs_member10
Dear Samsung Member,
We acknowledge your query and apologize for the inconvenience caused to you and will surely assist you regarding the same. Please visit this mentioned link to resolve your device issue: https://www.samsung.com/in/support/mobile-devices/how-to-prevent-the-overheating-of-your-galaxy-devi...
In case the issue still occurs. Please register your concern in Samsung Members Application (Open Samsung Members Application > Support> Tap on error report > Type your query > Send).
