Heating issue with S24 Exynos
(Topic created on: 03-22-2024 06:55 PM)
imprabhash
Samsung S24 exynos version is heating a lot, while charging or while using social media apps only, what the hell samsung, Phones at this price you are giving exynos instead of samsung and you cant evern optimise heating.
Do not buy S24 if samsung is not fixing this heating issue.
How will your phone rhn for 7 years if you keep on running on heated device
7 year update simply feels a gimmik as your exynos cant run for 7 years. And why is this discrimination of launching exynos except for US and canada? And even price is same or on higher side only.
ViruKU
I am using Samsung 12 years ago a s ultra f m all model using but s24 90000 cost but battery backup low 🙏 fix it
MeetOG
At this point samsung just wants to book good profit and doesnt care about quality, customer needs.
Rapidhunter
I also have this heating issue. The phone started to heat up with normal use, even on standby.
cs_member10
Dear Samsung Member,
As per your query, we request you to share the log file. This will help us to further investigate and resolve this issue.
To attach the log file: Samsung Members Application (Open Samsung Members Application > Support> Tap on error report > Type your query > Send).
imprabhash
Sure next time i face heating issue, I will share, with recent update, its heating lesser
lucio12
Yes same here s24 heating simply charging , using apps only .
ajsaty
S24 is heating a lot while using
I am also facing the same issue I am using S24, especially pubG and Signal app
jcmos
yes this phone is a lemon.
samsung released the Exynos 2400 too early, and we are being used as the test environment.
why cant we have the Snapdragon 8 g3?
my s24+ gets hot, battery drains quickly and mobile network signal is a joke! 1 to 2 bars.
Samsung needs to make up to us and give us duscounts towards other samsung products like watches.
7 years of updates on this lemon pho ne. i hope in one of those updates they fix the mobile network signal which is very poor.
Samsung, we spent lots of money on this phone that has lots of issues, give us something in return for you F up
vbha
I am facing a heating issue.
