Heating Issue and battery drain
(Topic created on: 08-22-2024 09:53 AM)
ArunVikki
In S24 Ultra
After updating the August security patch, the device is overheating within a few minutes of use. I am using it indoors with the air conditioner on, but it is still heating up excessively.
This problem did not occur before installing the August update.
The phone is heating up to nearly 50 degrees.
What the hell samsung!
Is anyone got this same error!
12 Comments
abdulDriftsyt
Bro this is nothing my phone was heating upto 60-61 degrees with August update
ArunVikki
So high bro
can you notice before august update
Bro, I also updated the August patch, but I don't have face any heating issue on my device.
surya7670
Which model?
ArunVikki
s24 ultra
surya7670
Using the same but I am not facing battery drain problem and it's been 3 days since I have done the upgrade.
Prashantbgh
Model ?
ArunVikki
s24 ultra
utsab123456
same issue on s23 ultra with slightly less heating but huge battery drain
