Galaxy s9 plus Battery Issue
(Topic created on: 10-04-2020 07:53 AM)
Jishnu1
Yesterday i replaced the battery from Samsung service center. Then i fully charged my s9+ at night. Then i removed the charger. After i kept the mobile till today morning with out using. (No wifi No 4g )
The new battery drains fast. The battery percentage was 89%. Screen on time is 0. Even with the old battery i didnt face this issue, with out using the mobile.
 Can you help me to solve the problem.
GALAXY S9 PLUS
4 Comments
fhd500
give it one week
then try this test again
because sometimes charging the battery many times give back the power to it maximum
Jishnu1
200 Derhams
Samsung_specialist
Hello there,
Battery percentage may vary according to the usage (internet, call, video playback, etc..). However, if you feel that the device battery drains quickly when no function is used, please send the device to one of the service centres to discover and fix the problem - www.samsung.com
Thank you
Jishnu1
Ok thanks for the reply
