3 weeks ago (Last edited 3 weeks ago ) in
Galaxy S- Mark as New
3 weeks ago in
Galaxy SAnd also.....
3 weeks ago in
2 weeks ago in
Galaxy SThank you for contacting us and sharing your concern regarding battery drain on your Galaxy earbuds.
General Troubleshooting:
Check the Galaxy Wearable App:
Ensure both earbuds are draining at a similar rate. A significant difference may indicate a problem with one earbud.
Update Software:
Make sure both the Galaxy Wearable app and earbuds firmware are up to date.
Navigate to Wearable app > Earbud settings > Earbuds software update.
Reset the Earbuds:
Place both earbuds in the charging case.
Open the Galaxy Wearable app.
Go to Earbud settings > About earbuds (or Reset).
Select Reset and follow the prompts.
Clean Contacts:
Ensure the charging contacts on both the earbuds and inside the case are free of debris or earwax.
Factors Affecting Battery Life:
Volume Level: Very high volumes drain the battery faster.
Connection Stability: Weak Bluetooth connections require more power.
Advanced Software Adjustments:
Disable unused features in the Wearable app.
Turn off 360 Audio in Sound quality and effects.
Disable Voice Detect and Auto Switch if not in use.
Limit app notifications allowed to the earbuds.
Check Accessibility Left/Right balance slider is centered.
Listen at moderate volume; download music to reduce continuous streaming.
Occasionally allow full discharge and then recharge to 100% to recalibrate the battery meter.
Hardware and Physical Checks:
Thoroughly clean the charging contacts on earbuds and case.
Remove ear tips and gently clean sensors, mesh, and charging contacts with a soft, dry cloth or cotton swab.
Verify earbuds are seated properly in the case; indicator lights should show correct charging status.
Remove any third-party protective case from the charging case, which may interfere with charging or connectivity.
Following these steps should help identify and resolve battery drain issues.
