Galaxy s24 ultra battery draining issue
(Topic created on: 3 weeks ago)
nazimnazer
I have been using galaxy s24 ultra for more than a month, my galaxy s24 ultra doesn't last longer than 5 hrs,, pls help me find the solution for this issue
7 Comments
Do Factory Reset
Use On FHD+ Resolution
On Performance Profile
nazimnazer
I have already done that
Raja_Jk
Background running apps to be closed. Some apps will run in the background even we close.
Try it in FHD or HD mode to check battery drain.
sometimes updates will fix this issue.
Raja_Jk
If problem continues take a back up. Reset.
Use it for some days to check.
Then restore.
mrlyngdoh
Bro I'm using both 15pm and s24ultra i never got more then 4 hour never on anyphone
Sarthak07
It might be because of March security update.
cs_member10
Dear Samsung member,
9. Reset the device:
IMPORTANT:
• For this:
