11-29-2024 01:28 PM in
Galaxy S- Mark as New
11-29-2024 02:37 PM in
12-02-2024 03:06 PM in
Galaxy SDear Samsung Member,
As per your concern, we would request you kindly perform the following steps to resolve your issue by the given links.
● Galaxy device Battery drain issue: https://www.samsung.com/in/support/mobile-devices/how-can-i-optimise-and-extend-the-battery-life-on-...
→ Update the software if available: https://www.samsung.com/in/support/mobile-devices/samsung-galaxy-smartphone-how-to-update-software/
→ You can reset your device by following the steps.
If the issue still occurs, please visit the service center for a physical inspection of your device. The price of the battery for the model S22 ultra is Rs. 2,120+18% GST and the final cost for the battery replacement includes the service charge provided by the service center only.
You can locate your nearest service center with this given link: https://www.samsung.com/in/support/service-center/
