Resolved! Solved
Galaxy S8 battery replacement
(Topic created on: 10-08-2019 06:02 PM)
sashaa
Hello all,
I want to get battery of my 2 years old galaxy S8 replaced through Samsung authorized service centre since I get very less SOT of hardly 2 hours. I enquired in the service centre where they told me that after battery replacement IP68 kit will also be applied and the device will be tested.
My question is has anybody done the battery replacement before? Is it worth spending the amount? Are there an issues coming after replacement?
Anshu
2 year is ideal time for battery replacement.
good decision....you will not repent, if you are not considering upgradation in near future.
10 Comments
Møňū
yes ip68 kit will also applied and device sealed.
sashaa
has the battery backup improved?
Møňū
just good from first
Anshu
sashaa
thank you
navisingh
It is mantarory for a service centre to apply waterproofing seal for water resistant phone, its a suggestion by samsung but some service centre doesn't apply it........just say them strictly to apply seal
sashaa
Not applicable
if your screen is damaged the service center with will change screen as well as battery but in any case first you consider reseting the phone
VaibhavKalband
how much does this battery replacement costs ?
