Galaxy S7 edge Red line issue.
(Topic created on: 01-04-2023 10:00 AM)
Mithun19742003
Hi There
All of you are aware that Samsung S7 edge has a manufacturing fault! It's screen getting a red line after few months to few years later after manufacturer.
Is there any know how this red line issue can be solved?
Mithun
mithun19742003@gmail.com
8 Comments
rohans69
Man its too old ,even if there was a problem,its irrelevant nowadays.
Just forget the device or keep it in the self as a wintage device.
Thanks. But I would like to know is there any Samsung responsibility about this issue?
rohans69
Like I said its too old , can't do anything about it, samsung service centre won't have a single spare part of the device.
Even the software department might have abandoned.
Thanks
Sid_Karna
Even newer Samsung flagships like s20 plus are having this issue. Many models are affected by this issue due to probably poor quality materials used.
It means Samsung has no care about their customers right?
Sid_Karna
We have to assume something of that sort!
cs_member8
Dear Samsung Member,
We acknowledge your query and apologize for the inconvenience caused to you and will surely assist you regarding the same. We request you to kindly visit the service center for a physical inspection of your device. You can locate your nearest service center with this given link: https://www.samsung.com/in/support/service-center/
