Galaxy S21 Ultra blurry camera issue
(Topic created on: 04-02-2022 12:11 PM)
Faizan14322
This is my first reported issue:
I am having this issue for the second time with s21 ultra camera, let me tell you all this happened with my old s21 ultra device as well and this is my second s21 ultra from my relative.
Issue:
Camera app blurry from 1X to 2.9X
however everything works fine before 1X zoom
And from 3X zoom everything is clear I have attached screenshots as well for your reference
I have seen many of the user have reported this issue hardware issue is not a problem according to me, howcome every s21 ultra user is reporting the same issue then
SAMSUNG SHOULD FIX THIS ISSUE💔
Via update as soon as possible
I have tried everything earlier also and now also
Steps performed :
Camera app clear data
Reset camera setting
Resetted the whole phone as well
Cleaned the lenses with microfiber cloth
Still issue persists😶
Please see the screenshots attached you will be able to understand, kindly comment in the comment box if you're also facing the same issue with your s21 ultra device.
Thank you.
83 Comments
TheMystic
Try another camera app that uses its own post-processing. And let me know.
Faizan14322
Please suggest any
Faizan14322
I have tried install gcam android 12 build but its not opening any other ?
Even zoom Quality is completely degraded beyond 30x..and 100x is now waste
Faizan14322
This is why apple is preferable
TheMystic
For photography, Samsung is really the king overall.
Faizan14322
But right the same camera module is not working bro as expected
TheMystic
Complaints of camera blur and display issues scare me the most. If you haven't dropped your phone or subject it to environments it is not designed for, i really can't think of any reason other than the software update causing all these problems. The number of people reporting these problems is quite significant.
While it is much less probable, we can't rule out a QC issue with the camera module too. In which case, replacement is the only option.
Faizan14322
I have never dropped my phone buddy, never used it in any extreme condition, I believe its a software issue becoz sometime the focus comes in, once a blue moon
