Galaxy S20 FE battery drain issue
(Topic created on: 03-31-2021 09:25 PM)
ishan1
On screen time is not even 4-5 hours on normal usage. I also tried following steps to save battery life but that does not even worked. This is very very disappointing. I wasted money on Samsung smartphone. I won't buy Samsung again in my entire life. They make fool of FANS.
And fast charging is not working too.
Totally waste 4500mAh battery....
ishan1
That you mentioned in some other related post
Ehsank
Hmmm! Then from 100-0 % 4-5 hrs?🤔
ishan1
Didn't find much difference
Ehsank
Did you check which app consuming more battery in battery uses?
ishan1
I think it's One UI Home, which is also running in background continuously.
Ehsank
One ui home is not an issue check apps
ishan1
No there is no such app
Ehsank
How this is possible dear🤔
ishan1
See many other users are also facing the same issue, i am not the only one so there is some big issue which is not related to specific app.
Ehsank
I know but what other user facing ,is not ur solution you have to do something to resolve yours, i think 🤔
Anyway keep sending feedback to Samsung
