Front camera problem
(Topic created on: Wednesday)
_raj_ib
After the June update on my S23 device, I'm facing a problem with the front camera. When I switch from the back camera to the front camera, it takes 9-10 seconds. Is anyone else facing the same issue?
3 Comments
SUBU99
Yes dear.
Just turn off the shot suggestion in your camera settings.
It's a bug which everyone is facing now after the June update.
Hope it will help for sure.
SUBU99
Please reply must.
cs_member10
Dear Samsung Member,
● Clear camera application data: Apps>Camera>Storage>Clear Data
● Clear cache memory of a particular application: Settings > Apps > pick the app > Storage > Clear Cache.
● You can reset your device by following the steps:
3. If you do not remember password then advise to reset (Forgot password) your Google account.
In case the issue still occurs, kindly visit the service centre for a physical inspection of your device. You can locate your nearest service centre with this given link: https://www.samsung.com/in/support/service-center/
