Front camera issues in s24 ultra
(Topic created on: 4 weeks ago)
Deepak-ace
After applying face smootheness in front camera before and after clicking picture are totally different, after clicking picture image looks really bad and also after updating to one UI 7 filters are really bad
2 Comments
Mani4
Samsung has degraded to promote new flagship
cs_member10
Dear Samsung Member,
● Kindly check the physical condition of your camera lens, such as broken camera lens or scratchy camera lens.
● Kindly camera lens cleaning: Use a microfiber cloth or a cleaning wipe. Gently remove the fingerprints, dirt, and dust from the camera lens.
● Reset the camera settings: Tap on Camera>Settings>Reset settings>Reset.
● You can reset your device by following the steps:
3. If you do not remember the password then advise to reset (Forgot password) your Google account.
Path: Settings> General Management.>Reset>Temporary cloud backup or External storage backup>After backup tap on Factory data reset to reset your device to its factory default settings.
If the issue persists, kindly report the problems with a log file. To share a log file, Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> select the appropriate issue category> Type your query and send.
