Front Camera Issue
(Topic created on: 10-26-2024 03:58 PM)
Azmrell
I don’t know about others, but when I take selfies with someone else, the camera most of the time blurs out the person behind me, making their face unrecognizable. This wasn’t an issue before. Is there a solution to this, or has anyone else encountered the same problem with their front camera? "Device: S 23 Ultra" One UI 6.1. #s23ultra #camera #frontcamera
9 Comments
Please visit in samsung camera settings and reset the setting
Azmrell
I tried, but it didn't fix ...
Please can you show of your selifie camera image and camera settings screen shots
Ok I think no settings problem please visit nearby samsung service center
Azmrell
THANKS
Azmrell
But I think it's because of the updates, because it wasn't like this before. After a few updates, it started to give me these kinds of results. Could that be the reason?
Ok please visit the service center I think they provide you good service
Azmrell
Okay
cs_member10
Dear Samsung Member,
As per your query, we would request you kindly perform the following steps to resolve your issues.
● Kindly check first if there are any broken camera lenses or scratches on the camera, no laminated or tempered glass is pasted on the camera if not then check after the camera lens cleaning.
● Use a microfiber cloth or a cleaning wipe. Gently remove the fingerprints, dirt, and dust from the camera lens.
● Reset the camera settings: Home screen tap on Camera>Settings>Reset settings>Reset.
●Clear camera application data: Apps>Camera>Storage>Clear Data
●Check app cache: Settings > Apps > Camera> Storage > Clear Cache.
If the issue persists, kindly report the problems with a log file. To share a log file, click on the Samsung Members Application (Open Samsung Members Application > Support> Tap on send feedback> Choose Compser> Select error report> select the appropriate issue category> Type your query and send.)
