Fast charging doesn't work in S10 lite
(Topic created on: 07-30-2023 06:48 PM)
PankajS10Lite
Superfast Charging not working in my phone from last 2 weeks. It only shows charging not fast charging on screen. I'm using original Samsung adaptor and cable. The option for superfast Charging is enable. I already reset the battery by dialing *#9900#. But nothing works.
Also when I connect charger to my phone, it automatically repeatedly shows connected and disconnected. Also sometimes when I remove cable, my phone repeatedly shows USB connector connected and disconnected.
Kindly help me.
5 Comments
umesh30
Test the 'Battery Status' and 'Cable charging' test in diagnostics section in this samsung member app... After the test, tell me that both tests are showing normal or not...
PankajS10Lite
I'v checked my charger in another phone and it's working fine. I have tried other chargers which are less than 5V which are working fine in my phone. Also I have tried multiple samsung chargers, they are not working. What may be the problem. Do I need to visit samsung care? How much they will charge for fix my device?
cs_member10
Dear Samsung Member,
We acknowledge your query and apologize for the inconvenience caused to you and will surely assist you regarding the same. We request you to kindly visit the service center for a physical inspection of your device. You can locate your nearest service center with this given link: https://www.samsung.com/in/support/service-center/
PankajS10Lite
Thanks...I visited the service centre yesterday...they replaced the charging port which cost me very expensive.
PankajS10Lite
I'm facing screen flickering problem after repair of my handset
