Facing stutter problem
(Topic created on: 05-02-2025 07:03 PM)
Archon
Is there anyone facing stuttering issue after updating to one ui 7 on s23!?
I'm facing the problem while opening or closing an app after the one ui 7 update...
Let me know in the comments if you're facing the same.
Thank you.
5 Comments
Yes there are some jitters here and there. Even it lags a bit while unlocking the phone sometime
Archon
Yes facing exactly same issue
Nilesh_Shah
You may want to wipe cache partition or do factory reset
cs_member10
Dear Samsung Member,
We request you kindly share the log file. Also, share the video clips and images for better understanding. This will help us to investigate further and resolve this issue.
To share the log file: Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> Select the appropriate issue category> Type your query and send.
Archon
After resetting the device, 80% of the problem seems solved.
