Facing problem in camera switching in video mode
(Topic created on: 02-21-2025 07:47 AM)
Saeed18
Dear Samsung team
We are facing problem in Camera switching in Video mode while recording is on. It will work only in 30FPS that if we zoom in main camera it will switch to telephoto ultrawide and periscope during camera recording but
It will not switch in 60FPS it will record only in 1 Camera at a time either ultrawide, main, tele, periscope. While other smartphone like iphone it will switch all the lens during recording.
We are requested you to please fix this issue on GALAXY S23ULTRA this is Samsung Flagship Phone.
2 Comments
Santosh_PURI
Please 🙏 report the samsung service by call toll free no.
cs_member10
Dear Samsung Member,
At Samsung, we always aim to provide impeccable services to our customers, and we highly regret that you feel this way.
Please follow these easy troubleshooting steps which may help in resolving this issue:
● Reset the camera settings: Tap on Camera>Settings>Reset settings>Reset.
● You can reset your device by following the steps:
3. If you do not remember password then advise to reset (Forgot password) your Google account.
Path: Settings> General Management.>Reset>Temporary cloud backup or External storage backup>After backup tap on Factory data reset to reset your device to its factory default settings.
If the issue persists, kindly report the problems with a log file. To share a log file, Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> select the appropriate issue category> Type your query and send.
