07-13-2025 06:45 PM in
Galaxy S- Mark as New
07-13-2025 06:57 PM in
07-13-2025 06:58 PM in
Galaxy SOpen Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> Select the appropriate issue category> Type your query and send.
If you find this helpful please Accept it as a solution It helps others. Thank you 😊
07-13-2025 07:35 PM in
07-13-2025 07:36 PM in
07-14-2025 09:20 AM in
Galaxy SDear Samsung Member,
● Kindly check the physical condition of your camera lens, such as broken camera lens or scratchy camera lens.
● Kindly camera lens cleaning: Use a microfiber cloth or a cleaning wipe. Gently remove the fingerprints, dirt, and dust from the camera lens.
● Reset the camera settings: Tap on Camera>Settings>Reset settings>Reset.
● You can reset your device by following the steps:
3. If you do not remember the password then advise to reset (Forgot password) your Google account.
Path: Settings> General Management.>Reset>Temporary cloud backup or External storage backup>After backup tap on Factory data reset to reset your device to its factory default settings.
If the issue persists, kindly report the problems with a log file. To share a log file, Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> select the appropriate issue category> Type your query and send.
