Facing lagging problem in S23
(Topic created on: 12-08-2024 07:41 PM)
Yash_T
S23 is lagging specially when I remove device from pocket & scroll down notification center it just lags over there is it a software glitch or something eles
5 Comments
TheMMM218
Not happening with me..update to latest version or factory reset it once
Yash_T
Its up to date
TheMMM218
I have s23 not seen such issue till now
Thokchom2024
Ok😊, from your information,
I can surely tell u that ur phone is going through very hard time as he hasnt been sleep since waking.
Kindly grant me the phone and send it to me. I will surely take his care and will be cured in 1week only😂🙏😂
cs_member10
Dear Samsung Member,
● Check space availability: Settings > Battery and device Care > Storage.
● Check RAM in your device: Settings > Battery and device Care > Memory.
● Check app cache: Settings > Device care > Storage > CLEAN NOW.
● Clear cache memory of a particular application: Settings > Apps > pick the app > Storage > Clear Cache.
● Close Background Apps.
● Remove third party application.
● Remove memory card: Apps > Settings > Device maintenance > Storage > More option > Storage settings > SD card > Unmount.
● Remove third party accessories.
● Enable/ Disable sensitivity touch: Settings> Display >Touch sensitivity.
● You can reset your device by following the steps:
If the issue still occurs, please visit the service centre for a physical inspection of your device. You can locate your nearest service centre with this given link: https://www.samsung.com/in/support/service-center/
