Facing echo problem in s21 fe 5g
(Topic created on: 09-19-2024 10:12 PM)
ujjawalkr
Person im talking to on the phone hears echo of their voice
3 Comments
goodthings
Please reset all settings of your's device in general management settings then try to it's again. If you like please accept as a solution it's help to others users also, click on 3dots in my reply section and click on accept solution. Thanks.
goodthings
Your's most welcome to here.
cs_member10
Dear Samsung Member,
As per your concern, we would request you to kindly perform the following steps to resolve your issues.
Galaxy device microphone issue: Disconnect the headphones and follow the below steps:
Remove any third-party case, protective films, or any other accessory that usually comes in contact with your device.
Restart the device: Press & hold the power key> Restart> Tap again to Restart your phone.
Note: If you use the security feature, the phone will require your backup password to unlock after rebooting.
Record your voice without using headphones by using a voice recorder" and playing the recorded audio:
Navigate to the apps screen and tap on the Samsung folder> Voice Recorder> Tap on the recording to record your voice then tap on Stop to save the recording> Save> Select and tap on recently recorded audio to hear the audio quality.
Note: If the recorded audio quality is good, then your microphone is working fine.
You can reset your device by following the steps.
3. If you do not remember then advice to reset (Forgot password) his/her Google account.
Path: Settings> General Management.> Reset.> Tap on Temporary cloud backup or External storage backup> After backup tab on Factory data reset to reset your device to its factory default settings. This will erase all data, including files and downloaded apps.
Note:
In case the issue still occurs, kindly visit the service centre for a physical inspection of your device. You can locate your nearest service centre with this given link: https://www.samsung.com/in/support/service-center/
