Facing 'Camera failed' issue in my S23
(Topic created on: 11-19-2024 05:41 PM)
GauMou
Beginner Level 4
Recently I bought a S23. And I just love this gadget but in Recent time i have being facing a camera issue on my front camera. Often when i open the camera app and switch to front camera, the camera freeze and a 'Camera failed' dialog box pops up. I thought it may me a small bug which would be fixed in the upcoming updates but no, after keeping the phone up to date i still get this error and its embarrassing.
How could I fix this issue??
25 Comments
Gundra
Hope they make changes in camera unit too
Aryankumar_28
Ok let see what one ui 7 bring new
goodthings
Kindly complaint to Samsung customer support through Samsung Members App as error report also send log files Along with this error report for this issue and wait for next update may be fix it by Samsung team soon. Also go to service center for resolves this issue. If you like please accept as a solution it's help to others users also, click on 3dots in my reply section and click on accept solution. Thanks.
goodthings
Your's most welcome to here.
cs_member10
Dear Samsung Member,
As per your query, we would request you kindly perform the following steps to resolve your issues.
● Google have recently released a new August Google Mainline addressing Camera failed issue. you can easily install this update through the Google Play System Update option on their device.
Path: Here are the steps to follow: Go to Settings > Navigate to Security & Privacy >Select Update >Choose Google Play System Update>Restart your device to complete the installation.
Note: This will ensure that your device is updated to the latest Mainline version.
● Reset the camera settings: Tap on Camera>Settings>Reset settings>Reset.
● Clear camera application data: Apps>Camera>Storage>Clear Data
● Check app cache: Settings > Apps > Camera> Storage > Clear Cache.
● You can reset your device by following the steps:
If the issue persists, kindly report the problems with a log file. To share a log file, Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> select the appropriate issue category> Type your query and send.
Samsung Customer Support"
