Resolved! Solved
Dual Audio Feature removed from Bluetooth Settings 😭
(Topic created on: 12-04-2019 12:24 PM)
GauravK21
Please Add Dual Audio in Bluetooth back .. That feature was very important and much needed one and it is now not available on Galaxy S10+, Note 10 or Note 10+ and even S9+ and Note 9 after ONE UI 2.0 Update .. Earlier it was present in Android 9 and One UI 1 .. Samsung please bring back that Feature..🙏
Resolved!
Gst26
It's Go..Went..Gone..
rjrcks
there is a update for it in media which is present in the notification panel just swipe down noti panel and then open the media setting and then open the about media and devices then u shld get the new update
GauravK21
Ok will try ..
NishitMehta
Yes Its There in Media And Devices You Have To Tick Both Devices Which you Want to play
GauravK21
Okk will try that ..
Mansb
a bala on kaysa karaga
Vix
i don't have this dual audio feature on M30s :(
Samsnote9
Please bring back the feature of Dual Audio. It was a must have feature in fladship.
GauravK21
No it's present under Media Tab
kartiksharma156
any ss how to find it???
