Resolved! Solved
Dual Audio Feature removed from Bluetooth Settings 😭
(Topic created on: 12-04-2019 12:24 PM)
GauravK21
Please Add Dual Audio in Bluetooth back .. That feature was very important and much needed one and it is now not available on Galaxy S10+, Note 10 or Note 10+ and even S9+ and Note 9 after ONE UI 2.0 Update .. Earlier it was present in Android 9 and One UI 1 .. Samsung please bring back that Feature..🙏
Not applicable
some people say that it is available under media and devices panel but I dont think that it is available here
23 Comments
Not applicable
GauravK21
I haven't tried that yet but will definitely try it in Evening and reply with Update here...🙌🏻
Not applicable
yeah sure bro
Gst26
Go..Went & Gone...
Not applicable
may be you are right
RohithkiranS
Expert Level 3
bro ,check this one in settings
Not applicable
this is different
GauravK21
This is something else..
GauravK21
In Dual Audio you can pair 2 Bluetooth Headsets simultaneously and use then together.
