Does S24 Ultra camera protector fit S23 Ultra
(Topic created on: 12-10-2024 03:00 PM)
cameralensprotector
Beginner Level 4
Hi all,
I'm looking to buy some camera protectors for my new Galaxy s23 ultra.
I see in some of the websites the protectors are compatible with both s23 ultra and s24 ultra. I am struggling to find a good one that are not too expensive.
I am seeing reviews where Spigen ones have focus issue.
ESR is a bit expensive at ₹1000 for s23 ultra. Also at the same time the s24 ultra protector from ESR is a bit cheaper at around ₹800 and that too for 2 packs unlike s23 ultra that comes with one piece.
Can any of you let me know if s23 ultra and s24 ultra share the same camera dimensions and will the s24 ultra ones fit the s23 ultra.
Thank you.
6 Comments
novq
Why use a camera protector? It can diminish image quality, and the camera lens glass is quite durable, so it may be unnecessary. Ultimately, the decision rests with you.
Thanks for feedback, after seeing so many negative thoughts about them I'm having a second thought.
But I still can't shake the feeling that they are not protected as is.
Do you think are there any good protectors that may work out in terms of picture quality as well as safety? I'm not a hard-core photographer BTW so a tiny bit of compromise is fine with me.
Or is there any alternate solutions except the case or protector that I'm aware of?
Thanks
novq
Then ESR and Spigen should have the highest quality.
That's what I thought, I'll test it out myself. Thank you for your feedback 😊
novq
Welcome 😊
Spigen_in
Consider the Spigen Tough Armor Back Cover case for camera protection; it safeguards the camera from damage and shields the sensor from UV rays and direct sunlight, thereby extending its lifespan. This top-selling item boasts 3,129 Amazon reviews; I recommend purchasing it. Please use below link for our official amazon store.
https://amzn.to/4gfE9iZ
