Resolved! Solved
Display issue
(Topic created on: 07-30-2024 08:23 PM)
kushpvt
Firstly,my device is s23
It has been 2 months of purchase
The problem is
At downside of left corner a small portion is lightly whitish
As I googled it all says screen bleeding
But if screen bleeding is the cause it should be on both white and black colours of screen
But in my scenario on black colour it is completely fine👍
But on light colours it has the problem can anyone please help me???🙏
Also I have checked temper glass.No problem with it🙃
HELP...!!
Resolved!
67 Comments
kushpvt
Without warranty...did you pay for that?? If soo who much did u pay and what's your model??
Dini256
S23, 10k for new display.
NOMAĐ
You should get it replaced.
As you mentioned, you can see this only on grey not black.
Since it is amoled display, black colour won't light up the led. So you won't see it. Whereas grey colour gets the bleed.
You have warranty. Get it replaced.
kushpvt
OK broo I will contact them but what might be the issue??
NOMAĐ
Maybe water seepage or due to humidity. Just a guess. Or could be manufacturing defect.
I've had the exact problem in S22 plus after warranty expiry. I've washed the device couple times in water. Maybe because of that water got into it. Exchanged it for S24.
kushpvt
I have warranty will they do it ??
What about glue gate issue??
NOMAĐ
They should do it.
I'm not sure it's light bleed. I've had this issue only after an year.
kushpvt
Okay broo thanks....if lightbleed is the issue will they do it for free??
NOMAĐ
Whatever it is, they must do it.
They will deny it only if liquid damage indicator strip inside device has turned pink.
kushpvt
OK brroo👍
