Display flickering in low brightness
(Topic created on: 10-23-2021 01:55 AM)
inbarasankumar
In Last two days my mobile (samsung s10 lite) started to flickering i reached the service centre and changed to software but again im facing the same issue but before 5 hours i noticed that when i put my phone in low brightness phone start to flickering but in full brightness no flickering and perfectly working. Why its happening only in low brightness, it is display problem or some other issue ?
4 Comments
sachin7575
Same problem bro.. that's why...am waiting October update
Not applicable
Try using some apps to limit flickering. Google about it.
Dear Samsung Member,
We acknowledge your query and apologize for the same. We request you to kindly visit the service center for a physical inspection of your device. You can locate your nearest service center with this given link: https://www.samsung.com/in/support/service-center/
SKS87
Am also facing same problem. Any solution found ?
