03-29-2024 01:46 AM in
Galaxy S- Mark as New
03-30-2024 08:13 AM in
Galaxy SDear Samsung member,
As per your concern, we would request you kindly perform the following steps to resolve your issue.
Reset app preferences: Settings > Apps > More option > Reset App Preferences.
Kindly try to connect your device with "other devices" and check.
Clear cache: Settings > Apps > Menu > Show system apps > Search
and type "Bluetooth" > Bluetooth > Storage > Clear cache > Clear data > OK.
The clear cache memory of a particular application:
Settings > Apps > Now pick the app that you like to clear off the cache memory > Storage > Clear Cache.
Reset settings: Settings>General Management>Reset> Reset all settings to their default.
Reset network settings: Reset Wi-Fi, Bluetooth, and other network settings to their default.
Check your device in safe mode: https://www.samsung.com/in/support/mobile-devices/safe-mode-on-samsung-phones/
Reset your device: https://www.samsung.com/in/support/mobile-devices/samsung-galaxy-mobile-how-to-perform-a-factory-res...
In case the issue still occurs, please visit the service centre for a physical inspection of your device. You can locate your nearest service centre with this given link: https://www.samsung.com/in/support/service-center/
04-30-2024 03:39 PM in
