Data saver consume battery?
(Topic created on: 08-08-2024 01:18 PM)
Ashutosh_595
Does data saver consume consume battery or help in battery drain?
3 Comments
MR_PRIME
No never.
Somehow it would be benificial for battery and processor.
Plz Accept solution clicking on 3dot right side nd Do follow for any help & Regular Updates.
Pi9T99
No Data saver does not consume battery.
If you think you got the answer then "Accept Solution" click on the 3 dot
cs_member10
Dear Samsung Member,
As per your query, we want to inform you that Data Saver is a feature that helps reduce your mobile data usage by limiting background data usage for apps. This means apps won't use data unless you're actively using them, helping you saving data and battery life.
