DEVICE CARE/BATTERY STATS/NOT SHOWING
(Topic created on: 01-02-2021 03:40 PM)
Sidhabhi
I found that NOTE20/S20/S10 LITE SERIES USERS ARE FACING ISSUE WITH DEVICE CARE/BATTERY STATS ARE NOT SHOWING..
ONLY FOR DEVICES RUNNING ON UI3.0/ANDROID11
All Galaxy devices that have been updated to the final version of Android 11 and One UI 3.0 have a unique bug, device no showing battery statistics.
Please try temporary solution..It worked for few users, you may try and see if its working for you guys or not??
Go to settings>Apps>Click 3 dots at top right corner>select show system apps>scroll down to Samsung device Health manager service>select it>clear data
Now, use your device for a while,then charge your device and check once again..
Note: IF NOT WORKING TRY IN SAFE MODE
ALSO, IF ANY USER WHO ALREADY HAVE SOLUTION, PLEASE SHARE YOUR INPUT..
PLEASE TRY THIS AND SEE IF ITS WORKING OR NOT..👍👍👍👍
24 Comments
Here is the link for some users:
https://www.sammobile.com/news/one-ui-3-0-battery-stats-2021-bug-on-galaxy-phones-fix/amp/?__twitter...
For others after these steps in safemode things are working fine.
Notadeveloper
Its working, clear data device health manager service , thanks to guy who found the solution :)
Notadeveloper
Its working, as i did way it was showcased in Sam Mobile
kk100
not working in m31 beta update Android 11
In beta anything is possible..so you guys can send feedback to Samsung(beta feedback section)
JohnnyMac
I found the article on Sammobile and tried it on my S20 5G UW. Still not working properly. I also use Battery Bot which pulls data from the Samsung UI and it has the same problem. Everything was running smoothly until the first of the year. I think the fix needs to come from Samsung.
Yes that's why I mentioned temporary solution .
Notadeveloper
I have clearly mentioned it stable and their solution for error reports. Reporting about stable oneui 3 bug, and they asking to enroll beta program which ended quite some time back.
I feel the oneplus feedback specialists had more brains, atleast they understood whats the report.
will report this..👍🙂
