Connection problem or invalid mmi code
(Topic created on: 05-23-2024 10:08 PM)
NeYoO720
How to solve this issue in s21 fe every time i used to check anything it gives this type of issue please someone address this issue and tell me how to solve it
5 Comments
AGalaxyuser
Turn off auto blocker from settings app. Turn it back on after you're done with your work for your privacy.
NeYoO720
Thanks
unknown_s
Please Turn Auto Blocker From Setting(Security And Privacy But Turn It On After Work Complete Because It Is Important For Your Privacy
If it's Helpful For You Please Consider This Comment As Sollution 🙏
By Clicking On Three Dot Present Above This Comment→Click on Accept Sollution
goodthings
Please go to setting, click security and privacy and click Auto Blocker and turn off Auto Blocker immediately then try to it's again it's works properly also after use this code or any other code again turn on Auto Blocker for your's device security. If you like please accept as a solution it's help to others users also, click on 3dots in my reply section and click on accept solution. Thanks.
cs_member10
Dear Samsung Member,
As per your query, we would request you to kindly perform the following steps to resolve your issue.
Disable Auto Blocker:
1. Go to Settings.
2. Select Security and Privacy.
3. Select Auto Blocker.
4. Then turn it Off.
In case the issue still occurs, kindly report the problems with a log file. To share a log file, click on the Samsung Members Application (Open Samsung Members Application > Support> Tap on error report > Type your query > Send).
