Sim 1 showing connection problem or invalid MMI code
(Topic created on: 01-26-2026 01:42 AM)
Phor123
I have been using the Samsung Galaxy S24 FE for about 1.5 months. After a few days of use, the SIM network shows full signal in the status bar, but I am unable to make or receive calls.
When someone tries to call me, they hear a message saying that my number is switched off. Only messages work properly.
 I reset my phone once, and after the reset it worked fine for about two weeks. However, today the same issue has appeared again. What could be the problem?
9 Comments
MANI67
Sim issue change sim
Phor123
The same SIM card works in another phone. I even tried a different SIM card, and the same error showing.
MANI67
Reset device then try
Phor123
I have important data on my phone, and resetting it repeatedly is not a solution. I have already reset the device once, and the issue returned after two weeks. How many times am I expected to reset the phone? This is very frustrating.😪
MANI67
Contact service center
L9🔥l
goodthings
Kindly turn off Auto Blocker in security and privacy settings then try to it's again. If you like please accept it's a as solution it's help to other users also,click on 3dots in my reply section and click on accept solution. Thanks.
goodthings
You're welcome to here.
cs_member10
Dear Samsung Member,
As per your concern, you have already done the possible troubleshooting steps and the issue remains unresolved, we kindly request that you visit our service center. Our technical team will be able to inspect your device physically and provide you with detailed information and assistance.
You can locate your nearest service centre with this given link: https://www.samsung.com/in/support/service-center/
