Connection issues on Samsung S21 FE
(Topic created on: 03-19-2024 07:40 AM)
Aashirwad28
My Samsung S21 FE is facing weird problem using Vi internet.
Notification bar shows signal but no connection while surfing.
Tried changing SIM to other phone. Sim works well on other phone.
Tried with other sim in my mobile also. That also works fine. Changed APN, reset mobile networks, etc but no solution
Anybody can offer some solution.??
Anybo
6 Comments
suman6746
Port to AIRTEL or Jio. Or you can try sim swaping.
Aashirwad28
Thank you will try that
goodthings
Please reset network setting of both Sim one by one and than reset all settings of your's device in general management settings also Flight ✈️ mode on n off one time, restart your's device without any Sim in slots, interchange Sim in slots, turn off power saving mode then try to it's again. If you like please accept as a solution it's help to others users also, click 3dots in my reply section and click on accept solution. Thanks.
Aashirwad28
Thank you for your help
goodthings
Your's most welcome brother 🙏.
cs_member8
Dear Samsung Member,
As per your concern kindly visit this mentioned link to resolve your issue: https://www.samsung.com/in/support/mobile-devices/samsung-galaxy-smartphone-how-to-optimise-network-...
In case the issue still occurs kindly visit the service center for a physical inspection of your device. You can locate your nearest service center with this given link: https://www.samsung.com/in/support/service-center/
