Vibration issue with my s23 ultra While receiving call and notification
(Topic created on: 03-19-2024 07:22 AM)
fen1l
Hi everyone,
Its wierd that after resetting my S23 Ultra canadian ver. I am hearing wierd vibration sounds when i receive call every one around me notice that i am receiving a phone call,
When i figuring this out more deeply.
It happens when i am receiving a call and when i am adjusting the vibration intensity of call in settings with slider.
During notifications and receiving calls via other applications like whatsapp, textnow or Facebook messenger it behaves normal.
I also checked vibration in phone diagnostic it seems to be okay, and i also checked vibration in hidden diagnostic menu *#0*# it is okay over there too.
I tried to disable bixby, bixby call, changed vibration intensity to the lowest from settings issue is same.
Anyone has any idea what is going on how i can solve this issue.
I apriciate all comments with solutions.
Thanks
3 Comments
goodthings
Kindly reset factory data without backup of apps then try to it's again. If you like please accept as a solution it's help to others users also, click 3dots in my reply section and click on accept solution. Thanks.
goodthings
Your's most welcome to here.
cs_member8
Dear Samsung Member,
As per your query, we request you kindly visit the service center for a physical inspection of your device. So that they can check the exact issue with the device and fix it at the earliest. You can locate your nearest service center with this given link: https://www.samsung.com/in/support/service-center/
