Confused between s22 plus, s23 FE and regular s23
(Topic created on: 10-05-2023 12:13 PM)
av04
Hi everyone,
I am considering buying new phone in Rs 50-60k range. Considering S22 plus, S23 FE and regular S23 as an option. My main requirement is good battery life, decent camera and overall smooth performance. I am confused among the three phones mentioned. Any inputs will be greatly appreciated.
S22 plus is almost 2 years old now. But is has a snapdragon processor and good camera.
S23 has a better and much more efficient processor but much smaller battery. I am afraid of the standby battery drain.
S23 FE is the latest one but has a two year old processor and that too Exynos 2200 😶. It feels like s22 plus with an inferior processor. S22 plus might have a better battery life.
What do you guys think? Which one would be the best option?
20 Comments
S23 anytime 😊
piyussh07
1st choice to drop - S23 FE 🫣
Communicator
S22+
Do you want bigger screen size ?
I would suggest S23 as comes with Snapdragon 8 Gen 2 and has good battery life, good camera and 5 years of software updates
ThePhotography
Go with S23 if you like small phones
Otherwise choose s23fe if you want slightly bigger display.
But my suggestion is Go with Oneplus 11, it's a very very good phone & you'll definitely satisfied after using it.
Otherwise pixel 8 is very good option.
But it's your choice....
Just choose wisely.
Devv_007
Go for S23 ,one of the best phone samsung has made after many years, and don't even consider s23 fe ,its just an e waste.
iamMUKESH
One plus 11 or s23 regular
S23 fe me too exynos processor aayega, wo dukhi krega
Go for S23 regular, if you are samsung fan
Nischay-S24U
S23 has improved over s22 in terms of battery perfomance.
S23> S22 plus> S23FE
8 gen 2 of S23 is battery efficient and what they call dynamic amoled increases the battery life
Dips27
S23
