Charging problem in S10
(Topic created on: 05-23-2020 04:37 PM)
Mita2
Phone stop Charging after some time... it only show fast Charging and not showing time to complete charging
7 Comments
kpu
same problem
solution try charging in cold place
eg- front of cooler
deepak0099
I am also facing similar issue. does this solve the problem ?
kpu
yes
typically
this WAS
AravindanR
Even if it does not show the estimated time left, your phone is still getting charged. so you do not have to worry about it. If it takes longer than usual then it might be due to hot weather.
Samsung_Support3
Dear Samsung Member,
Please perform the below mentioned steps to resolve the issue:
1. Kindly check the power socket functionality with a different device or try to charge the device in a different power socket.
2. Check connectivity
Please check whether the charger cable and adapter is fixed well. Remove charging cable and reconnect with mobile phone properly.
For further assistance, register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report/Ask questions).
