Charging Issues in Samsung
(Topic created on: 4 weeks ago)
Rajkiran082
My recently(4 days) bought S25 Ultra and Watch 8 Classic has been very annoying with their charging speeds. They randomly switches to slow charging without any app running or any other processes. This same problem present in both Phone and watch is really weird to notice. Samsung needs to work on this really quick. However the battery life is also very mediocre compared to the competition. 7 Hours of Screen time with light usage.
2 Comments
cs_member10
Dear Samsung Member,
Please perform the below-mentioned troubleshooting steps, these may help in resolving your concerns.
1. Galaxy device Charging issue: ● We always recommend to use genuine Samsung charger for charging your device.
● Check your charging cable (USB cable) for physical damage such as wear and tear, bent prongs etc. If it is damaged, then kindly visit your nearest service center to get it replaced.
● Kindly check the charger functionality with a different device or try to charge the same device with a different charger.
● Check charging: If rating is 15W or above: Kindly try to charge the device in a non-inverter socket.
● If you using normal socket: As a safety measure Fast charging may not support, while you are using the device hence, request you to keep the device idle and check the charging performance.
Note: Kindly open Device care from settings > tap on Battery > tap on More battery settings > Fast charging > Turn on.
● Kindly follow the standard charging procedure. i.e. please charge the device in switched-off condition for 10 minutes.
● Turn off unused functions like Wi-Fi, GPS, Bluetooth, and location settings when not using them: On the home screen swipe down the notification panel > Turn off Wi-Fi, GPS, Bluetooth, and other connectivity features when not using them.
● Kindly check if ''Multiple applications'' are running in the background of the device. When running multiple applications, the processor processes more tasks and as a result, additional heat is released from the device. This happens with most electronic devices (even computers/laptops), including the devices of other manufacturers. Close all the background running apps when not using them.
● Avoid usage of mobile phones during charging. Usage of the mobile phone when charging may cause slow charging issues. So we recommend you avoid the usage of the mobile phone while charging.
3. If you do not remember password, then advise to reset (Forgot password) your Google account.
Path: Settings> General Management>Reset>Temporary cloud backup or External storage backup>After backup tab on Factory data reset to reset your device to its factory default settings.
2. Galaxy watch Charging issue: ● Kindly check the charger functionality with a different device or try to charge the same device with a different charger.
● Kindly follow the standard charging procedure. i.e. please charge the device in switch off condition for a minimum of 10 minutes.
● Turn off unused functions like Always on Display, Wi-Fi, GPS, NFC, Bluetooth & Location settings when not using them.
● Avoid usage of watch during charging it may cause slow charging issue. So we recommend you to avoid the usage of the watch while charging.
● Update software: https://www.samsung.com/in/support/mobile-devices/update-software-on-your-samsung-galaxy-watch/
● Reset the watch: Swipe to and tap General > Reset > Reset again to confirm.
Note: Before performing the factory data reset, don't forget to backup all the important data stored in the Galaxy Watch.
If the issue still occurs, please visit the service centre for a physical inspection of your device. You can locate your nearest service centre with this given link: https://www.samsung.com/in/support/service-center/
Rajkiran082
I'm using Samsung verified official chargers only. And as I mentioned, I was not using the devices while charging🙏. The problem is on your side only. 🙏
