Charging Issue on Samsung Galaxy S23 - Unable to Charge Above 81%
(Topic created on: a month ago)
Kemster
I am writing to report an issue with my Samsung Galaxy S23. Whenever I charge my phone, it does not exceed 81% charge, even though it has been plugged in for an extended period.
I have tried several troubleshooting steps, including performing a reset and toggling various settings as suggested in support articles, but the issue persists.
Could you kindly assist me in resolving this problem or provide further troubleshooting steps?
12 Comments
CipherChip
First, check if the 'Protect Battery' or similar setting is enabled in your phone's battery settings, as this may limit the charge. If this is not the case, I recommend using the Samsung Members app's diagnostic tool to test your battery.
Kemster
I have done all the thing protect battery setting is off and also i have use diagnostic test but it show normal but charging not increasing
CipherChip
lf you find this useful, then click on the three dots given above this message and accept it as a solution.
ShomitSarkar
I think this replies to everything.
CipherChip
Here are some additional steps you can try:
* Check your charger and cable: Make sure you are using a Samsung-approved charger and cable. Inspect them for any damage. Try using a different charger and cable to see if that makes a difference.
* Clean the charging port: Sometimes, debris in the charging port can prevent a good connection. Gently clean the port with compressed air.
* Check for moisture: If your phone detects moisture in the charging port, it will not charge. Make sure the port is completely dry.
* Check fast charging settings: Ensure that fast charging is enabled in your phone's battery settings.
If none of these steps work, it may be necessary to contact Samsung Support or visit a service center.
tsspmo
Check in setting if protect battery is on. If its on then close it
ag85
Battery protection is on turn it off from battery setting
Wodehouse
Disable Adaptive battery and battery protection. If after doing this you still get it get it checked at service centre. Overload protection circuit will need a close look.
If this reply answered your query please tap 3 vertical dots to the right of my reply and tap "Resolved". Thank you 😊
sp1277
Beginner Level 3
Go to settings -> Battery-> Battery Protection..and if Battery Protrction is ON..then you will get 3 options.
Basic..
Adaptive
Maximum
I think you have selected Maximum option..
Change it to Basic.
It will charge upto 100%
If my info gives your answer then i m happy.🙂
